Shorten Taranis Sticks
Has anyone shortened the length of the sticks on the Taranis?
I'm persistently having my thumbs slip off the sticks when I'm flying, super awkward in races...
I've realised that the sticks on the taranis are just a bit too long, to a point my thumb is awkwardly bent in order for me to fly - causing it to slip off.
Anyone got a solution?
solution 1:
I removed the pointy parts and the set screws to reduce the height. To really shorten them you have to remove the set screw and thread that hole to 3mm and bottom the skirt out on the gimbal face.
solution 2:
You can buy new sticks on amazon that are sharper also
Solution 3:
Go get some aluminium PlayStation pads, remove the top bit of the sticks and covered with with paw pads. Nice and comfortable and no slips
I use the flysky FS-i6 sticks on my taranis. the spikes are much sharper than the stock taranis ones. I think they have them on banggood
  BetaFPV Elrs module not loading in a taranis X7 Stumpy 2 198 31-Jan-2024, 12:19 PM
Last Post: Stumpy
  Solved Betaflight 4.5 elrs rx no sticks input Mad35 7 397 26-Jan-2024, 08:47 AM
Last Post: Mad35
  Help sticks do not respond after a few meters lucasho 7 337 12-Sep-2023, 10:09 PM
  Taranis & TD 100 [km] zomer 0 193 03-Sep-2023, 03:27 PM
Last Post: zomer
  Help RSSI callout Taranis QX7/OpenTX? swequad 1 266 13-Jul-2023, 03:05 PM
