Shielded wires might be very beneficial for many FPV components: camera and VTX, GPS, maybe gyro (I am not sure ).
What I know about shielded wires as a fact:
1. It should be grounded (a shield should be connected to ground). Otherwise no effect or even worse.
2. One point of ground. Otherwise it will cause a ground loop ( I don't exactly understand it, but I know it's very bad)
But my question is where to ground?
One option I've heard is to ground to the battery minus.
Like this:
BTW, wires I want to shield
1. Camera to FC
2. FC to VTX
3. GPS to FC
4. DIATONE MAMBA Interference Shielding FPC Board (not exactly a wire, but should be grounded as well)
Another option is to ground to "signal ground".
Actually I don't know what is "signal ground".
Maybe it is the same GND pad, it means to solder 2 wires to one pad. Like this?
What is the best option to connect shielded ground to prevent EMI, RFI and other nasty noises.
What are your thoughts?
Like this:
1. Camera to FC
2. FC to VTX
3. GPS to FC
