Threads: 125
Likes Given: 99
388 15-Nov-2023, 06:12 AM (This post was last modified: 15-Nov-2023, 06:13 AM by voodoo614.) Check for loose motor screws? Or other loose screws.
Threads: 1
Likes Received: 14 in 12 posts
Likes Given: 8
0 Put new props on, it solves 95% of vibration issues.
Threads: 172
Likes Received: 2,283 in 1,830 posts
Likes Given: 4,721
100 sounds like it carries to much weight, what battery do you use?
Threads: 74
Likes Received: 1,338 in 998 posts
Likes Given: 781
41 Doesn't look like a big chunky battery on it, but maybe. I would say try some lower pitch props for starters and new props. Tighten all motor mount screws and maybe threadlock them too (or at the bare minimum threadlock 2 out of 4). Make sure the props are screwed/bolted down. That stutter didn't sound all that bad, like over in less than a second.
As BadRaven mentions, we need flight footage, also blackbox data if you have it. Beyond that post your config up and take some pictures of the quad and post them up here so we can have a look for anything obvious.
Try Not, Do or Do Not
- Yoda
Threads: 29
Likes Received: 405 in 305 posts
Likes Given: 322
18 15-Nov-2023, 08:15 PM (This post was last modified: 15-Nov-2023, 09:00 PM by Suros.) I kinda wonder if this is more troubles with the ICM 42688-P. I get the same kind of thing. What version of Betaflight are you running?
Edit: Guess that depends on how new yours is. It's possible yours has a BMI270 if it's a little older if I'm seeing things right.
