22-Apr-2016, 06:19 AM
I've had the dead cat for some time, and decided to upgrade from the KK2.1.5 to an extra SP Racing F3 I had. I'm new to all of this, so have only the barest idea of what I'm doing. Once installed, I connected the FC to cleanflight and proceeded to setup everything. Since cleanflight doesnt (yet?) have a config for dead cat, I used a custom mix from the CLI. To calculate the values, I used 3 different methods. One methods was to calculate the values based on the distances between the motors and CG for each axis. THe second method was the trig method using the angles of the motors from the CG of each axis. THe third method was to use the online tool here. All three methods produced similar enough results I moved forward with the ones calculated using trig. Once saved, I tried to take off. At this point the quad pitched forward before truly lifting off. I then tried the other two sets of values I had, same result. I then thought maybe the rear motors had too much throttle authority, so I reduced throttle for those motors to .80 in the mixer. It now doesnt pitch forward, but it does roll right, quite enthusiastically! I should note here that I had already checked to ensure that each motor was turning in the correct direction, and that the correct props were mounted.
Any suggestions what to do/try next? I'm at a loss.
Configuration:
Frame: HK450, dead cat
FC: SP Racing F3
FC is turned 90 clockwise, and I set the yaw adjustment in cleanflight to compensate.
These are the most recent commands I've used (also tried with throttle for motors 0 and 2 set to .8):
mixer custom
mmix 0 1 -0.765 0.632 -1
mmix 1 1 -1 -0.632 1
mmix 2 1 0.765 0.632 1
mmix 3 1 1 -0.632 -1
Configuration:
FC: SP Racing F3
mixer custom
