Seriously Pro Racing F3 Mini Flight Controller (SPRacingF3Mini)
[Image: Vrd5OKll.jpg]
Cleanflight creator is releasing a new board: Seriously Pro Racing F3 Mini Flight Controller (SPRacingF3Mini)
I think they realized onboard flash memory is too limited for blackbox, so they built in SD card slot for logging and that was a good move, same with the race transponder, the board can finally live up to its name.
No extra voltage regulator means a cleaner build.
And no more annoying JST-SH connectors, everything else gets real through-holes. MUCH better design than the original.
But I hope that it is strong enough to take a hit without breaking given there are so many holes.
Seems to be FAR better than the original SPRacing in terms of features as well as getting rid of the micro connectors. If it turns out to be reliable (not randomly conking out like the original), I may get one.
Some of the features that caught my eyes:
Race Timing Transponder
The SPRacingF3Mini is the first and only mini board that features a race transponder system for recording your lap times. Each board comes with a special transponder code to identify you at race events. Compatible with i-LAP receiver systems. Two LEDs for clockwise and anti-clockwise race tracks.
Built-in 5v regulator (BEC)
The built-in 5V regulator makes wiring-up simpler and cheaper. Fixed-wing aircraft also become so easy: connect receiver, battery, 2 servos and an ESC and you're done!
MicroSD
The SPRacingF3Mini is the first and only mini board that features a MicroSD card socket for logging. Supports MicroSD/SDHC up to 32GB!
USB
The only full-featured mini-size board with USB socket which is not shared with serial ports. No more hassle configuring or flashing.
I love to share and help people! Flying Mini Quad is the best!
Really nice and neat stuff.
But
what will it cost?
If it's expensive like the last one, then again nobody will buy it or only get replicas
Sky is where the fun begins!
Flying: Armattan F1-6 / Cobra 1960kv / KISS / 1800mAh nano's / SPR3 / Betaflight 2kHz
Building: FPV49v4 modified
  orqa fpv.pro ? hugnosed_bat 3 455 22-Sep-2023, 01:03 AM
  [New Book] FPV Flight Dynamics: Mastering Acro Mode on High-Performance Drones SnowLeopardFPV 103 15,753 16-Nov-2022, 02:08 AM
Last Post: the.ronin
  Betaflight to end development on F3 flight controller Oscar 8 8,529 15-Mar-2022, 06:46 AM
Last Post: Lemonyleprosy
  new nano rx pro hugnosed_bat 4 1,847 04-Feb-2022, 10:32 AM
Last Post: jasc
  Nebula Pro camera Nejo_FPV 10 877 07-Oct-2021, 10:51 PM
