Threads: 203
Likes Received: 346 in 264 posts
Likes Given: 306
11 I got a A110 and it’s getting a reading that it has a bad heating element.
Sequre wants me to take it apart and attempt to repair it but that will void the warranty.
The soldering iron won’t hold its temperature settings and temperature goes up and down from a bad element.
They say it’s a bad solder joint but taking it apart and attempting to repair it just seems like they know items are sent out defective.
I used PayPal but PayPal doesn’t seem to do claims anymore?
Threads: 125
Likes Given: 99
388 08-Jun-2021, 07:19 AM (This post was last modified: 08-Jun-2021, 04:01 PM by voodoo614.) PayPal claims suck. They only deal with you if you don't receive an item. Once received, they don't care if it works or not. When possible, I always use my credit card straight.
I always recommend a good soldering iron. Mine last for decades.
Threads: 589
Likes Received: 8,983 in 6,648 posts
Likes Given: 1,426
789 Yes, I've found PayPal to be worthless. They give it all the talk about "payment protection" but the reality seems to be very different when it comes to the crunch. Always use your credit card if buying something you want real payment protection on. I only tend to use PayPal as a convenience for low value items (eBay purchases) these days.
Unless you need a portable iron then get yourself a proper bench iron. They are far more useful in my experience. I have a TS80 portable soldering iron but I've only ever used it once, and that was to repair my bench soldering iron, so I had no choice but to use that one.
A Hakko or Weller are probably the best brands. I have a Chinese "Yihua" branded bench iron / hot air rework station which has been doing me fine for probably more than 5 years apart from that minor repair I needed to do (temp sensor wire came loose from the circuit board inside the wand).
Threads: 203
Likes Given: 306
11 Yes PayPal protection is basically non existent and some vendors hide behind PayPal.
Threads: 203
Likes Given: 306
11 Sequre ended up sending me a good iron.Actually two good irons after sending out 2 defective ones.
I think they may have gotten a better heating element update.
These new A110 are decent irons.
