Securing connectors with hot glue
I see on Oscar's blog the use of hotglue like substance on various JST type connectors.  I am building my first quad and it has lots of connectors and am trying to secure everything for its eventual multiple crashes, what are some best practices? i.e. Hot glue connectors together, to board, hot glue in back of connector to keep wire secure, on pdb, etc.?
Thanks.
(20-Mar-2016, 06:11 PM)CptanPanic Wrote: I see on Oscar's blog the use of hotglue like substance on various JST type connectors.  I am building my first quad and it has lots of connectors and am trying to secure everything for its eventual multiple crashes, what are some best practices? i.e. Hot glue connectors together, to board, hot glue in back of connector to keep wire secure, on pdb, etc.?
Thanks.
Hot glue is a temp fix, it actually softens up if used on any heat sources and just comes apart. I use 2 pack epoxy glue on all my connectors on my Flight Controllers and works really well.
I use liquid tape on PDB solder joints as it is is easy to remove when you need to do repairs.
  Adventures in Hot Air & Electronic Repair Lemonyleprosy 187 12,249 13-Oct-2023, 03:17 PM
Last Post: mattyfleischfpv
  Help Pitch axis oscillations and hot motors Extrm 0 311 08-Jul-2022, 07:54 PM
Last Post: Extrm
  U.S. Sellers of JST Connectors? the.ronin 3 338 12-Jan-2021, 08:19 AM
Last Post: voodoo614
  Hot after adding FPV KiwiLoris 0 664 07-Aug-2017, 05:23 AM
Last Post: KiwiLoris
  XM20A Running HOT Martin Eriksson 5 1,750 28-May-2016, 02:56 AM
Last Post: JimmyLe813
