second opinion on battery damage after crash
I just started flying a new build, an X-frame with the lipo strapped to the bottom. Now on a number of occasions already, I've scraped and landed on lipos harsher than I would like due to bad landing or simply crashing. I'm not worried about most of them, it's just scratches, but one was a bit skewed after a crash. It wasn't warm or hot and it hasn't puffed, but I'd appreciate a visual second opinion from you lovely lot.
I'm flying Turnigy Graphenes btw and they're relatively well-protected.
See the pics below. Should I be worried or extra vigilant of this lipo? Thanks!
[Image: 5IZRVOn.jpg]
[Image: p241QKA.jpg]
[Image: te4nGaN.jpg]
[Image: ZdCX0NS.jpg]
[Image: ORP9D9L.jpg]
At most, vigilance is probably enough. If you want that protective plate on there, you could remove the old heat-shrink, put it back in place and add new heat-shrink. (I'd just get rid of the plate myself.) If the battery charges OK, I'd say use it and forget it.
Or you could put a piece of wide tape over the end if it faces forward.
If cells aren't damaged, then just bend it back into its normal square form and keep on using it.
Thanks for the input. It's as I suspected but I'd so very much like to keep my track record of surprise in-the-face explosions at zero. Tnx!
  Discussion 4-6s battery charger advice balauru_327 11 493 19-Feb-2024, 03:57 PM
Last Post: jasc
  Solved Hd zero trouble shoot after crash Rob Axel 0 234 31-Jan-2024, 12:55 PM
  Li-ion Battery and Betaflight mlcasmey 11 1,190 26-Jan-2024, 01:18 AM
Last Post: StuweFPV
  Discussion Battery Dimensions segler999 2 206 19-Jan-2024, 05:39 PM
Last Post: segler999
  Need help finding battery replacement for T-drones Ares 6S 30Ah on US east coast Heimegut 1 217 15-Jun-2023, 10:46 PM
Last Post: Lemonyleprosy
