SBUS - X4R-SB channel values jumping around in Cleanflight configurator
I was trying to setup SBUS on my Flight controller (XRacer F3), and found the values on the Receiver tab just jumps around randomly.
I followed the necessarily steps, enabled Serial Receiver in configuration, setup the correct port as Serial RX.
Tried a different Flight controller and different X4R-SB RX, Still no joy...
Problem solved:
I forgot to change Serial Receiver provider!!! Changed it to SBUS and it worked beautifully...
[Image: noB4jezl.jpg]
  FC SBUS Out Rotems 2 276 18-Oct-2023, 09:00 PM
Last Post: Rotems
  Hd-Zero sbus on soft serial? Rob Axel 1 270 08-Aug-2023, 12:11 PM
Last Post: Pennywise
  Discussion which band and channel do you mostly fly hugnosed_bat 14 3,019 27-Jul-2021, 06:17 PM
Last Post: MrSolo
  Cleanflight and Emax Skyline 32 V1.2 Tony 1717 16 3,738 17-Nov-2017, 08:46 AM
Last Post: unseen
  Help X4R-SB doesn't bind with Taranis SBUS Oscar 1 1,745 06-Nov-2017, 07:46 PM
Last Post: raspberrypi33
