RX/VTX Antenna Mount
Sometimes you struggle to find that perfect spot for your RX antenna, and sometimes even your VTX antenna.
I stumbled across these a while back and have been using them on pretty much every build.
[Image: Screen%20Shot%202016-06-24%20at%2010.59....zxl7kv.png]
Little G10 mount to help you position your fpv antenna where you need.
Screw them to an m3 hole on the edge of your fame and this gives you a secure spot to mount the RX antenna or VTX pigtail.
I mount mine on the 2 rear stand off top plate screws and then use a cable tie looped through the larger hole and heatshrink the antenna to the cable tie.
I have only seen them at Buzzhobbies, http://buzzhobbies.com.au/index.php?rout...uct_id=223
At 78 cents US a piece it is nothing.
My youtube channel
  • sirdude
Hmmmm....I do believe that will come in handy on my upcoming build. Big Grin   Thanks Biggles!!!
Edit (30 seconds later)
Damn....everybody else must have thought so too...they're out of stock.
(24-Jun-2016, 03:42 PM)sirdude Wrote: Edit (30 seconds later)
If you have access to a 3D printer, you could quickly print out a dozen or so...
[Image: 1rJNVfrl.png]
Not exactly the same, but it should work (2mm thick, btw).  Just uploaded it to thingiverse: http://www.thingiverse.com/thing:1643292
(Let me know if it needs to be modified - it be easy.)
  • BigglesFPV
Appreciate it scotty, but I don't have access to one...been thinking about it, but as of yet I can't really justify it to the war department Confused (I shouldn't say that, my wife is absolutely great.......but she does have her limits : ))  Anyway, by the time I need it, they may have restocked. Smile
[-] The following 1 user Likes sirdude's post:
  • outlawzz
(24-Jun-2016, 04:11 PM)sloscotty Wrote: If you have access to a 3D printer, you could quickly print out a dozen or so...
Nice one ..Thanks for that..Will stock up now, and make coloured ones. Big Grin
My youtube channel
(24-Jun-2016, 11:05 PM)BigglesFPV Wrote: Nice one ..Thanks for that..Will stock up now, and make coloured ones. Big Grin
Well, print "one" first and check the dimensions.  Let me know if holes too big, too small, correct distance apart, etc.  I don't have one to measure, but it's painless for me to modify the model.
(25-Jun-2016, 01:14 AM)sloscotty Wrote: Well, print "one" first and check the dimensions.  Let me know if holes too big, too small, correct distance apart, etc.  I don't have one to measure, but it's painless for me to modify the model.
No problem, I will get the calipers out and measure the original I have, and let you know.
Don't mind my quick and dirty scratches on your nice diagram.
[Image: Screen%20Shot%202016-06-25%20at%2010.12....hn52fk.png]
My youtube channel
Thanks! I thought my antenna hole was a bit big.  Model adjusted - added V2 file at thingiverse link above.  (Everything else was very very close.)
Here's the revised snapshot:
[Image: Ue6CLUAl.png]
Doh!  Had already downloaded version 1 and printed. Version 2 will be spot on.  Once again, Nice work Scotty. Big Grin
[Image: Screen%20Shot%202016-06-25%20at%2011.54....ssp437.png]
My youtube channel
  • sloscotty
V3 and V3thin (1.6mm) added.  I suspect these will be too fragile, unless maybe printed in ABS or Nylon.  (Couldn't leave well-enough alone... Big Grin )
[Image: LSANHiAl.png]
(What the heck! V2thin too....I'll stop now....)
  • HamsterFPV, BigglesFPV
Looks good, I need to get my printer working again with all of these new designs coming out.
  Analog VTX for PAVO20 GlebSh 3 196 20-Apr-2024, 03:41 PM
  Help Vtx overheating battfish 3 235 04-Apr-2024, 12:05 AM
  New Product AKK Alpha 10 5.8GHz 10W VTX SnowLeopardFPV 8 399 19-Mar-2024, 05:54 PM
Last Post: Suros
  Help Random VTX frequency on power up cst3x6 7 411 27-Feb-2024, 10:16 AM
Last Post: cst3x6
  Help MO1 AIO V2.1 VTX not sending signal ThatOneGuy_ 0 158 24-Jan-2024, 09:44 PM
Last Post: ThatOneGuy_
