Running 3S on 12V Step down voltage regulator
Is it okay to run a 12v stepdown PDB, on a 3s battery, since the voltage on the LiPo can drop below 12V?
is that going to cause noise for the VTX?
I read someone mentioned this a while ago, and I am planning on doing just that in my building with a Amoway 200mw and Demon Core PDB.
I think it should be fine.
It shouldn't cause noise, it'll just output a bit less than the input voltage, because voltage regulator always has some voltage drop, typically around 1.2v, so you might see output is 1.2V less than the input when it's below 12V.
Though my RCX PDB does make some funny buzzing sound on 3S but not on 4S (apparently that's the switching regulator and it's normal)
  f7 blitz mini shows voltage is only 0.11 with 6s lipo plugged in Dronewhooper 11 277 13-Jan-2024, 05:35 PM
Last Post: V-22
  PLEASE HELP drone not detecting voltage NIC 2 258 21-Jun-2023, 09:53 PM
Last Post: NIC
  Fried 5V Regulator on Tyro 119 Radioactrev 16 1,478 31-Jul-2022, 09:24 PM
Last Post: Lemonyleprosy
  No Battery Voltage Reading in Goggles Weewhacker 8 2,115 22-Nov-2021, 08:14 AM
Last Post: Weewhacker
  Help diagnosing FC/ESC issue - voltage problems clone2002 11 1,216 12-Jun-2021, 04:11 AM
Last Post: clone2002
