30-Mar-2016, 12:30 AM
Which FPV Camera should I get? Runcam Swift, TBS ZeroZero, or HS1177?
Runcam Swift, TBS ZeroZero, or HS1177 FPV camera? |
30-Mar-2016, 12:30 AM Which FPV Camera should I get? Runcam Swift, TBS ZeroZero, or HS1177? I love to share and help people! Flying Mini Quad is the best! 30-Mar-2016, 12:32 AM Pick one that is IR sensitive so you can still fly well with it after dawn. Swift is IR-sensitive, HS1177 is also available in IR sensitive and IR blocked. IR sensitive picks up light sources better than than IR block. I can't fly too far away from lights at night with IR block. With IR sensitive as long as there's some light in the area you can see a whole lot more in the dark. Although I personally still use the PZ0420M IR-sensitive in all quads, best bang for your buck. 30-Mar-2016, 12:35 AM I recently bought the TBS ZeroZero and i was very disappointed about the quality. change of contrast from bright to dark is shockingly bad, very dark image has no contrast at all. And there's no joystick to change the settings. 30-Mar-2016, 12:37 AM (30-Mar-2016, 12:35 AM)CurryCat Wrote: I recently bought the TBS ZeroZero and i was very disappointed about the quality. I was having issue with mine as well, especially I was getting lots of lines while using the matek PDB and even if it filters the output power. I was about to buy the HS1177, but as soon as i connected the RRosd pro, all problems seems to be solved, image is very clear now and camera seems bright enough without adjusting it from goggles. I don't have tested in low light conditions though 16-May-2017, 06:24 PM Anything but the Zero2. You can't adjust the OSD as easily as the others so you're stuck with whatever default image settings out of the factory. |
TBS Fusion vs Rapidfire vs Speedybee VRX modules at same price, which is best? | Luk5569 | 21 | 761 | 09-Apr-2024, 09:03 PM Last Post: SeismicCWave | |
Announcement TBS Fusion 2.34 (Beta) Firmware Released | SnowLeopardFPV | 10 | 5,045 | 06-Mar-2024, 01:27 AM Last Post: SnowLeopardFPV | |
TBS UNIFY Pro32 | zomer | 5 | 257 | 27-Feb-2024, 10:02 AM Last Post: cst3x6 | |
New Product SpeedyBee 5.8GHz FPV Goggles Receiver Module (Analog) | SnowLeopardFPV | 2 | 1,311 | 14-Feb-2024, 03:24 PM Last Post: SnowLeopardFPV | |
Camera Plug Wiring | segler999 | 5 | 379 | 30-Dec-2023, 05:17 PM Last Post: segler999 |
