18-Feb-2019, 11:58 AM
Hi All
Can you switch between PAL /NTSC on this camera ??
Cant seam to find answer anywhere
Regards
Regards
Runcam Swift 3 (Switch between PAL/NTSC) Can you ?? |
18-Feb-2019, 11:58 AM Hi All Can you switch between PAL /NTSC on this camera ?? Cant seam to find answer anywhere Regards 18-Feb-2019, 12:27 PM Looks like they offer it in both, but the camera itself isn't switchable. You get what you're given based on shipping country, but can specifically ask for one or the other. Not sure what that means when buying through a third party ... Source: https://support.runcam.com/hc/en-us/arti...-my-camera- The ground is for dead people. 18-Feb-2019, 12:51 PM (18-Feb-2019, 12:27 PM)Banelle Wrote: Looks like they offer it in both, but the camera itself isn't switchable. You get what you're given based on shipping country, but can specifically ask for one or the other. Not sure what that means when buying through a third party ... I have accidently ordered NTSC And I think all my swift 2's are on PAL. Is NTSC effects video quality vs PAL ?? Regards 18-Feb-2019, 12:55 PM IIRC NTSC has a slightly higher frame rate, slightly lower resolution, and the colours are not quite as good. Honestly, I'm not sure it makes much difference besides having to change the setting in Betaflight's OSD tab (I get really flickery OSD if I set it to auto ;-) The ground is for dead people. 18-Feb-2019, 02:17 PM (18-Feb-2019, 12:55 PM)Banelle Wrote: IIRC NTSC has a slightly higher frame rate, slightly lower resolution, and the colours are not quite as good. Honestly, I'm not sure it makes much difference besides having to change the setting in Betaflight's OSD tab (I get really flickery OSD if I set it to auto ;-) So what I can gather is that there is no significant quality los between these formats Regards |
Pavo20 / Putting the light Strip on a Switch | TxFlyer | 12 | 581 | 26-Apr-2024, 10:38 PM Last Post: Paglia | |
Build Runcam Split Mini in 5" Armattan Chameleon | BagsFPV | 5 | 936 | 27-Mar-2019, 09:57 PM Last Post: voodoo614 |
