Threads: 1
Likes Received: 0 in 0 posts
0 I'm having a strange issue where if I try to fly with props my quad will freak out and jet up like I had punched the throttle at 45 percent. The same thing happens on both the kiss fc and a dodo. What could be wrong? I've already killed a motor trying to find out.
Threads: 7
0 Post a cli dump. I had a weird issue when min command and min throttle were to close together
Threads: 51
Likes Received: 1,861 in 1,175 posts
Likes Given: 3,315
74 I don't know anything about kiss or kiss config, but if it is exhibiting the same behavior with two different FC's (and evidently two different configurations from what I can tell), I would suspect my radio transmitter (and/or receiver). Maybe you have a "negative expo" (or something like that) set on the model in your radio? I suggest creating a new model on your radio and leave default settings, rebind, and go from there. Only idea I can think of.
Good luck! - Scotty
