RF Interference
Any idea what may fix this?
Note, this is RF interference, not electrical. There is a power filter in place. All of the grounds are good.
It sure looks electrical, given the picture is clear until you fire up the motors. When you say you have a power filter connected do you have your fpv cam and VTX running through it?
My youtube channel
(29-Jun-2016, 04:05 AM)BigglesFPV Wrote: It sure looks electrical, given the picture is clear until you fire up the motors.  When you say you have a power filter connected do you have your fpv cam and VTX running through it?
That's correct. It's possible that my VTX is damaged. I have a new one on the way.
(29-Jun-2016, 04:17 AM)DanInVa Wrote: That's correct. It's possible that my VTX is damaged. I have a new one on the way.
Good idea, always pays to have a spare on hand, even if it is just for testing purposes.
My youtube channel
  • DanInVa
I'd check if frame isn't grounded somewhere because You probably have antenna connectors touching it somewhere - hard to avoid that. Or solder a capacitor just for a quick check before a spare arrives.
  • Oscar
(29-Jun-2016, 08:20 AM)Konrad Stepanajtys Wrote: I'd check if frame isn't grounded somewhere because You probably have antenna connectors touching it somewhere - hard to avoid that. Or solder a capacitor just for a quick check before a spare arrives.
The frame is grounded. It's an LS210. There's a hole in the top plate specifically for attaching an antenna.
(29-Jun-2016, 12:58 PM)DanInVa Wrote: The frame is grounded. It's an LS210. There's a hole in the top plate specifically for attaching an antenna.
What I meant - check if other ground wires/pads aren't touching carbon somewhere, You may have some ground loop that's conducting small current.
  • DanInVa
  Interference when turning on the radio fra_gra 1 251 22-Dec-2022, 09:51 PM
Last Post: matt0725
  Help Strong wind causing interference with video signal Trial4life42 8 883 22-Aug-2022, 06:19 PM
Last Post: Lemonyleprosy
  Interference in short distance with steadyview receiver tomstell 5 798 26-Jul-2022, 12:22 AM
Last Post: kafie1980
  FPV Video with interference/black lines/jello mihhail 3 586 08-Jul-2022, 02:27 AM
  My first analogue build, some kind of interference? Zanna83 4 563 05-Aug-2021, 10:07 AM
