08-Jul-2023, 01:51 PM
Congratulations! Can you also help me, after updating the firmware of my tinigo, it only turns on the 4th engine, unfortunately I accidentally deleted the rollback file. I want to return to the factory settings, but not one of the firmwares on the manufacturer's website does not help.
I send the status via my drone.
# status
MCU F411 Clock=108MHz (PLLP-HSE), Vref=3.30V, Core temp=35degC
Stack size: 2048, Stack address: 0x2001fff0
Configuration: CONFIGURED, size: 3994, max available: 16384
Devices detected: SPI:1, I2C:0
Gyros detected: gyro 1
GYRO=ICM42688P, ACC=ICM42688P
OSD: MAX7456
System Uptime: 19 seconds, Current Time: 2023-07-08T12:42:04.476+00:00
CPU:42%, cycle time: 125, GYRO rate: 8000, RX rate: 143, System rate: 9
Voltage: 0 * 0.01V (0S battery - NOT PRESENT)
I2C Errors: 0
SD card: Not configured
Arming disable flags: RXLOSS CLI MSP
