RESOLVED: New build F450 - APM2.8
Thumbs Up
Hello guys,
I´m currently working on a new build, this time an F450 with APM2.8 (https://www.aliexpress.com/item/F450-Qua...0.0.JpECQO)
I noticed that this board has been retired when I try to flash the latest firmware, it´s ok as FlightPlanner app goes for the latest available FW for this board and the FW upload works just fine.
The problem here is: I cannot calibrate the ESCs after wiring them all.
When I click on ESC calibration I get the message: "Set param error. Please ensure your version is AC3.3+"
When I try to test the motors then I get a different error: "command denied by autopilot"
Any clue what could be happening ?
Thanks
EDIT: I figured out, it requires radio configuration before going to test motors, and calibration has to be done through the radio (high throttle + connect battery).
  Who wants to help me to build my first FPV? Several questions and concerns about how phelipems 3 95 13-Apr-2024, 12:09 AM
  First Build - prevent antenna chop? JohnnyCornRocket 5 197 28-Mar-2024, 02:16 PM
Last Post: iFly4rotors
  Best Battery Option for Build - Begginer Arkadius27 7 220 19-Mar-2024, 04:40 PM
Sad What to check for short in a build? Yesnok 1 140 03-Mar-2024, 12:06 PM
  First Build Critique Crashesintotrees 3 189 01-Mar-2024, 04:25 PM
