Replacement frame Nighthawk pro 200
Hey guys
I crashed my nighthawk multiple times, but yesterdays crash broke an arm.
Are there any frames (other than a nighthawk frame) I could use? The FC has an X layout so small X frames would not work.
I'm mostly looking for another frame, maybe 4mm (nighthawk was 3mm), that would either be more durable or have the option to replace the arms.
I always practice over soccer fields. So dirt and grass. I broke the arm crashing into grass.
There are a lot of good frames, so throw me your preferred brand or frame Smile
(After the crash, I could safely plug in the battery, but could not arm the quad anymore. Hoping for some minor issue. Will post pictures in a bit :p )
Lazie
I have beat the living  Poop out of my NOX5R if you can squeeze everything in it. It's more hybrid-X shaped than a true-X but still quite compact.
Also I have been thinking of a Pirate Frame for my next build. I linked to Zerpo's (one of the owners & designers) thread here on the forums instead of their webpage (his post has webpage link) just to show you the kind of people behind the frame as well Wink
The Obsession IS Real!
  • laziegoblin
https://gyazo.com/473af6286a1f5dc8349076a65d138b38
https://gyazo.com/a0d0f41deddf7357f63d5f6c6d8ed6f2
yeah, I fell in the same boat with the Vortex... I got the wrong version that was supposedly race-friendly (I don't really see ImmersionRC and race in the same light lol) and had 3mm arms.
You could probably go with just about anything with 4mm arms... I agree about the pirat... As mentioned in the thread it's my interest these days. TBH I went with a martian which has done me very well... I managed to do a 220 build on my first go which says a lot! (now that I know better... even if she is a little sick right now).
good luck on it! make it indestructible and beat the crap out of it and destroy it anyway! That's kind of the mode I am in right now lol.
carl.vegas
[-] The following 2 users Like Carl.Vegas's post:
  • laziegoblin, Drone0fPrey
Should I use sandpaper on the edges before using or not? https://gyazo.com/9eeb97e848306634a9db67a6c9a59ce1
IT ARRIVED!! Smile
(09-Jun-2017, 05:53 PM)laziegoblin Wrote: Should I use sandpaper on the edges before using or not? https://gyazo.com/9eeb97e848306634a9db67a6c9a59ce1
IT ARRIVED!! Smile
It helps remove any sharp edges that would cut into wires and straps.
If then sealed with a couple coats of CA glue, it helps to prevent delamination (spliting apart of the carbon fiber layers) in a hard crash.
Just don't forget to protect yourself, wet sand while wearing rubber gloves is my process to prevent breathing the dust and getting any in my skin too. Wink
Can't wait to see it come together! Popcorn
Once you're done sanding the edges, you can apply CA to seal it with a Q-Tip or hold the frame at a 45 degree vertical angle, apply a drop of CA and let the drop roll down the edge (this process is a little tricky but makes for a much nicer finish)
(09-Jun-2017, 08:37 PM)RENOV8R Wrote: Once you're done sanding the edges, you can apply CA to seal it with a Q-Tip or hold the frame at a 45 degree vertical angle, apply a drop of CA and let the drop roll down the edge (this process is a little tricky but makes for a much nicer finish)
Bad news. I was testing if the gear from the nighthawk was all working fine before I started trying to put it all on the pirate frame.
I tested my motors and the receiver. I had issues arming since the last crash. It seems the receiver has a hard time connecting to the transmitter. It finally worked. So I tested the motors. They started up nicely and then this thing decided to just stop doing anything.
[Image: a52e58b359677485822e58aedc2036b2.jpg]
https://gyazo.com/a52e58b359677485822e58aedc2036b2
[Image: 5db8edfdc191dc611b29c08b11cbcd36.jpg]
https://gyazo.com/5db8edfdc191dc611b29c08b11cbcd36
When I connect it to the computer it still gives me the sound of a USB connecting, but no lights on the FC blink and I can't open it up on Betaflight.
Poop hopefully one of our electronics/computer experts can help diagnose it and figure out if it is repairable.
  Meteor 65 pro replacement camera NewToFPV 19 419 19-Apr-2024, 06:19 AM
Last Post: NewToFPV
  4 inch frame with 16x16 motor mounting holes Pathfinder075 10 209 19-Mar-2024, 07:02 PM
  4" frame that fits GOKU HD 745 EVO 40A AIO Zorik_IL 5 251 24-Jan-2024, 03:00 PM
Last Post: skywanderer
  rush tank 2 ultimate wiring help to argus f7 pro Dice 1 166 21-Jan-2024, 12:09 AM
Last Post: matt0725
  Tango 2 pro sticks stuck daKnighty 0 144 31-Dec-2023, 03:16 AM
Last Post: daKnighty
