  • 1 Vote(s) - 5 Average
Remove Betaflight Notch Filters and Use PT1 | BF 3.1.7
Wow what a difference... Just with the PT1.
The # worked
carl.vegas
Hello, a newbie here (first sorry for my english, not my native language)
today i tried removing the filters on my quad. i was able to set it to PT1 and remove filter 1, when i removed the 2nd filter some of my motors started getting hot so i reversed and just stayed with filter 1 removed. my question is:
what happen when for example i hit a flag or a gate with quad during a race and keep flying with a bent prop or something else introducing vibrations to the quad in that moment? what i mean is if some people are not able to remove filtering because they have a noisy setup, what happends when a setup becomes noisy with that filtering already removed, is there any risk?
hope i was able to express my logic in an understandable way, thanks in advance.
[-] The following 2 users Like hailenp's post:
  • Carl.Vegas, Drone0fPrey
(13-Jul-2017, 02:03 PM)hailenp Wrote: Hello, a newbie here (first sorry for my english, not my native language)
Welcoime to IntoFPV hailenp! Also a great question, I hadn't considered it before but now am curious too.
carl.vegas
  • hailenp
#19
Im curious about this now also Smile
The Obsession IS Real!
  • hailenp
#20
In short: all hell can break loose Big Grin yes the risk is real - stuff might run hot quickly if filter settings are on the edge and you happen to bend or break a prop mid-flight.
The dterm filter settings depend on profile - you could make a second profile for example with a wider dterm notch and lower lowpass frequency (and maybe lower PID), so you could change profile quickly to continue.
[-] The following 2 users Like fftunes's post:
  • unseen, Carl.Vegas
#21
I might do that and then tie it into my airmode switch... at the point where I have a busted prop but am managing to still fly I don't want to be doing the kinds of things I need airmode anyway... even if rigth now my quads always have airmode enabled lol.
carl.vegas
#22
(14-Jul-2017, 08:39 PM)Carl.Vegas Wrote: I might do that and then tie it into my airmode switch... at the point where I have a busted prop but am managing to still fly I don't want to be doing the kinds of things I need airmode anyway... even if rigth now my quads always have airmode enabled lol.
Yeah, as i'm not a racer, at that point i usually "fly home" or just land/drop it somewhere safe, like when vibrations are so bad it hardly stays in the air and hardly can see anything... last time this happened i was missing 1 blade on my 2-blade props lol Big Grin
But sadly you can't change profile by switch (yet), only by stick commands while disarmed. It was announced for betaflight 3.2 a while ago though.
#23
you can't?
I was under the impression by one of the guys I fly with that you can. I might have to figure out what he's been doing and I'll have a look this afternoon to see if I can figure it out. Perhaps they're using 3.2 or something, I don't know
carl.vegas
#24
(15-Jul-2017, 10:34 AM)Carl.Vegas Wrote: you can't?
In the officially released versions so far you can change rate profiles  by switches but not profiles. Maybe that's what he meant?
#25
(15-Jul-2017, 11:48 AM)fftunes Wrote: In the officially released versions so far you can change rate profiles  by switches but not profiles. Maybe that's what he meant?
Ah, yes... that's it... I just automatically assumed if you could change rate profiles that you'd be able to change pid profiles too... Doh
carl.vegas
  Testing Betaflight 4.1, rpm filters, and other filters turned all the way down. 5zero7rc 0 956 27-Oct-2019, 12:13 AM
Last Post: 5zero7rc
  Betaflight 4.1 & RPM Filter's First Flight Sr.Irie 0 480 12-Oct-2019, 07:21 AM
Last Post: Sr.Irie
  betaflight 4.0 on the holybro kopis 2 test flight Krashcan 0 535 23-Apr-2019, 09:12 PM
Last Post: Krashcan
  Betaflight 2.9.0 | Nearing a GOOD tune | Himadri 6 1,245 30-Aug-2016, 05:51 PM
Last Post: Himadri
  Betaflight 3.0 PoorMan FPV 3 1,082 20-Aug-2016, 04:46 PM
Last Post: PoorMan FPV
