Posts: 5,314 Threads: 672 Likes Received: 3,155 in 1,743 posts Likes Given: 2,027 Joined: Jan 2016 Reputation: 139 24-May-2017, 10:42 PM (This post was last modified: 27-Mar-2018, 05:16 PM by Oscar.) https://oscarliang.com/filter-betaflight/ Benefits of using PT1 filter, and removing Notch filter - Your quad would response faster and feels more "locked in" and responsive because of the shorter latency caused by additional filters - That will give you the best results. Sharpest response, easiest tuning and literally no prop wash on good setups. drawbacks - more noise will get into your system and might cause oscillations and motor/ESC overheat Steps to remove filters in Betaflight - set d_lowpass_type = PT1 (in the CLI) should always be done first and I think possible on every setup
- hover your quad for 30 seconds, see if motors are hot. If they are you should revert back, If it is still fine than
- Remove notch 1 (set Freq = 0 in the config GUI or CLI to disable Notch filter)
- Fly for 30s and check motors temp again, still fine remove notch 2
- Now if your setup is still clean you could even remove dterm notch, although it might not make as much difference as the previous filters
This hack requires a clean build, such as having FC soft mounted and low ESR capacitor installed in the power or ESC. If motors get hot you should stop and revert back, your build is simply too noisy to have filters disabled. Here is a video showing the result Posts: 1,290 Threads: 67 Likes Received: 711 in 472 posts Likes Given: 1,216 Joined: Mar 2016 Reputation: 23 Nice flying Oscar (as always). "Damn the torpedoes!!! Full speed ahead!!!" Posts: 88 Threads: 5 Likes Received: 97 in 44 posts Likes Given: 66 Joined: Jun 2016 Reputation: 2 really was amazing weather today! removing the filters feels sooo good, looks so creamy Posts: 1,773 Threads: 30 Likes Received: 1,199 in 755 posts Likes Given: 714 Joined: Oct 2016 Reputation: 45 Awesome flying Oscar! It amazes me that such a simple adjustment can make such a difference. Prop wash be gone!! Posts: 1,590 Threads: 89 Likes Received: 1,283 in 768 posts Likes Given: 1,274 Joined: Jan 2017 Reputation: 31 I'll have to wait until I get into more soft-mounting to try but I'll keep this post in mind when I do... Video is awesome! you inspire me to re-look at my primary flying location, the super-empty field... maybe there are ways to make the perimeter more interesting! carl.vegas Current Quads: Operational: Diatone GT2 200 In need of repair: Bumble Bee, tehStein, Slightly modified Vortex 250 Posts: 2,410 Threads: 136 Likes Received: 1,790 in 1,052 posts Likes Given: 3,302 Joined: Jan 2017 Reputation: 50 Your rates are insane bruh! I have been thinking I should crank mine up a bit. I am to the point where I am trying to fit in quicker moves in tighter spaces, and find myself under rotating at times. • Posts: 5,314 Threads: 672 Likes Received: 3,155 in 1,743 posts Likes Given: 2,027 Joined: Jan 2016 Reputation: 139 • Posts: 2,410 Threads: 136 Likes Received: 1,790 in 1,052 posts Likes Given: 3,302 Joined: Jan 2017 Reputation: 50 (25-May-2017, 04:35 PM)Oscar Wrote: It's actually a lot lowered than I used to since we have super rate also play with SetPoint Weight, it largely changes your rates and expo as well... I will definitely. Thanks for the tip! Come to think of it I did have to play with SetPoint Weights on my micros to get them to feel right, compared to my 5". • Posts: 164 Threads: 36 Likes Received: 83 in 46 posts Likes Given: 124 Joined: May 2017 Reputation: 4 Nice flow Oscar! Quads: RealACC X6R ; RealACC X210 Pro, Omnifbus F3 FCs; RunCam Swift 2 & Swift 2 Rotor Riot, Emax OG Red Bottoms, Emax RS2205S 2300kv; Fatshark DOM V3 YouTube - Mr.E_fPv • Posts: 5,314 Threads: 672 Likes Received: 3,155 in 1,743 posts Likes Given: 2,027 Joined: Jan 2016 Reputation: 139 (25-May-2017, 07:23 PM)rryyyaann Wrote: Nice flow Oscar! thanks • Posts: 1,590 Threads: 89 Likes Received: 1,283 in 768 posts Likes Given: 1,274 Joined: Jan 2017 Reputation: 31 Code: Set d_lowpass_type=PT1
returns "invalid name" for me... Any thoughts? Am I doing something wrong? carl.vegas Current Quads: Operational: Diatone GT2 200 In need of repair: Bumble Bee, tehStein, Slightly modified Vortex 250 • Posts: 947 Threads: 66 Likes Received: 350 in 248 posts Likes Given: 164 Joined: Apr 2016 Reputation: 34 (02-Jul-2017, 06:33 PM)Carl.Vegas Wrote: Code: Set d_lowpass_type=PT1
returns "invalid name" for me... Any thoughts? Am I doing something wrong? Type "get lowpass" and you will find the command. It is probably just a syntax error • Posts: 344 Threads: 64 Likes Received: 465 in 171 posts Likes Given: 381 Joined: Sep 2016 Reputation: 18 03-Jul-2017, 10:22 AM (This post was last modified: 03-Jul-2017, 10:23 AM by Kerni_fpv.) (02-Jul-2017, 08:36 PM)oyvinla Wrote: Type "get lowpass" and you will find the command. It is probably just a syntax error you have to at "#" before! Code: #Set d_lowpass_type=PT1
and oscar this looks amazing it looks like you did have a plast while flying!! • Posts: 947 Threads: 66 Likes Received: 350 in 248 posts Likes Given: 164 Joined: Apr 2016 Reputation: 34 (03-Jul-2017, 10:22 AM)Kerni_fpv Wrote: you have to at "#" before! Code: #Set d_lowpass_type=PT1
and oscar this looks amazing it looks like you did have a plast while flying!! Hmm, thats strange. I never use # before any CLI command • Posts: 344 Threads: 64 Likes Received: 465 in 171 posts Likes Given: 381 Joined: Sep 2016 Reputation: 18 (03-Jul-2017, 10:37 AM)oyvinla Wrote: Hmm, thats strange. I never use # before any CLI command me to but did run in same trouble and with this it worked for me dont know why maybe a bug... • |
