Remapping motor to LED_strip Revolt OSD
Question
I've flashed betaflight on my Revolt OSD because one of the motors wasn't spinning and I found out it wasn't the ESC. The pad on the FC is bad because I used another motor in it's place and that one wouldn't spin either.
I was able to remap the motor to the LED_Strip resource on CLI but now I'm only getting a motor twitch instead of normal spin. What else am I missing to get this working properly?
Thank you in advance!
CLI Dump attached**
.pdf   cli dump.pdf (Size: 59.8 KB / Downloads: 67)
The settings look correct. Try swapping out for knew working esc and motor.
I got it fixed by switching the signal wires on the FC. I simply moved motors 1 and 2 then remapped them in CLI and for some reason it worked. I wish I knew why, but after hours of troubleshoooting I'm just happy. It's 420 so time to celebrate haha
Glad it worked. But it doesn't make sense to me why it worked.
  Semi Newbie here - T-Motor F7 Pro Full Function Tonestire 9 1,399 19-Feb-2024, 07:23 AM
Last Post: MontyFPV
  F4 1S 5A AIO FC ELRS Current Draw in OSD segler999 6 637 17-Nov-2023, 02:57 AM
Last Post: segler999
Photo Help Mamba F405 Motor 3 not working when LED added Toppers 20 3,575 01-Nov-2023, 10:21 PM
Last Post: onesimos
  HGLRC Zeus F722 + DJI AU + DJI GV2 - no OSD kubahomola 5 560 20-Jul-2023, 09:11 PM
Last Post: V-22
  Help T-Motor F7 Pro - Reciever priority (DJI) tfr33 4 530 01-Jul-2023, 08:30 PM
Last Post: Lemonyleprosy
