I present to you my RedRotor Strider Flex frame.
The build is a little over a year old and it shows some battle damage. The frame is high quality and has served me very well, and is generally well designed. but i dont fell i can be able to recommend it to anyone as the user base is small and it seems that the support from the RedRotor RC is quite low as well.
it sits at just about 600 grams AUW with over 4 Kg of trust on 4s
Frame: RedRotor Strider Flex. (modded)
Flight Controller : Naze32 running betaflight.
Reciver: FrSky X4R-SB (anti inverter mod)
ESC: KISS 30 amp
Motor: Cobra 2206 2100kv Racing edition
Props: HQprop 6045
Battery: Nano Tech 4S 1300 mAh
FPV cam: 700 tvl plastic case
FPV Transmitter: TS5823 5.8GHz 600mw
OSD: minimOSD
ESC: KISS 30 amp
Props: HQprop 6045
OSD: minimOSD
