27-Apr-2023, 02:59 PM
So I have a rp3 reciever and elrs zorro transmitter it binds but I get no stick input on betaflight any help would be great I been pulling my hair out for 2 weeks?
Reciever and transmitter |
27-Apr-2023, 02:59 PM So I have a rp3 reciever and elrs zorro transmitter it binds but I get no stick input on betaflight any help would be great I been pulling my hair out for 2 weeks? 27-Apr-2023, 03:43 PM When you power up the RadioMaster RP3 receiver do you get a flashing LED on it, and when you then switch on your RadioMaster Zorro does the LED turn a constant colour? If it does both of those things we at least know the receiver is properly bound to your Zorro. If the above is all fine then please run both the "dump" and "diff all" commands in the Betaflight Configurator CLI tab and copy/paste the results back here. Please also post some good clear photos of the actual wiring and connections between your receiver and flight controller. 27-Apr-2023, 04:58 PM No it flash all the time but I have a binding phrase when I flashed them and I get telemetry when I power my reciever but my reciever is still flashing 27-Apr-2023, 04:59 PM Will do when I get home in a little bit! Grrr it's so frustrating 27-Apr-2023, 05:05 PM Also should I have wired it to tbs nano uarts or smartphone as shown in the picture it is a rp3 reciever 27-Apr-2023, 05:06 PM Smartport uarts not smartphone sorry lol 27-Apr-2023, 05:08 PM (27-Apr-2023, 03:43 PM)SnowLeopardFPV Wrote: When you power up the RadioMaster RP3 receiver do you get a flashing LED on it, and when you then switch on your RadioMaster Zorro does the LED turn a constant colour? If it does both of those things we at least know the receiver is properly bound to your Zorro. It's a tmotor f7 pro 2 hd stack and rp3 reciever 27-Apr-2023, 06:33 PM If the LED on the receiver is flashing then it's not bound properly. Have a look at the link below to identify the status based on the type of flashing pattern you are seeing... https://www.expresslrs.org/quick-start/led-status There is no point posting a CLI dump or photos of the until you have rectified the binding issue because until that is sorted out you won't get see any stick movements even if the wiring and Betaflight settings are correct. 27-Apr-2023, 10:00 PM (27-Apr-2023, 03:43 PM)SnowLeopardFPV Wrote: When you power up the RadioMaster RP3 receiver do you get a flashing LED on it, and when you then switch on your RadioMaster Zorro does the LED turn a constant colour? If it does both of those things we at least know the receiver is properly bound to your Zorro.I got it going man thanks also I have a new problem when I land and arm when I disarm it won't disarm 27-Apr-2023, 10:48 PM (27-Apr-2023, 10:00 PM)Jayrock93 Wrote: I have a new problem when I land and arm when I disarm it won't disarm I'm not sure what you mean by won't disarm. If you were able to arm the quad in the first place with a switch that you configured for doing that then flipping the same switch the other way will disarm the quad. I don't see any reason why you wouldn't be able to disarm a quad. 26-Sep-2023, 06:28 PM woH woH (27-Apr-2023, 10:00 PM)Jayrock93 Wrote: I got it going man thanks also I have a new problem when I land and arm when I disarm it won't disarm How did you get it going??? I have the same exact issue, I have a Zorro and an RP3, and when I turn them both on it says "Telemetry recovered" But no solid light and stick inputs. 26-Sep-2023, 09:39 PM SoS oS (27-Apr-2023, 10:00 PM)Jayrock93 Wrote: I got it going man thanks also I have a new problem when I land and arm when I disarm it won't disarm So within the "MODES" tab in betaflight you should have your arm switch configured. With your quad plugged in and your transmitter connected, flip you arm switch. If it turns yellow that's good and then flip it to your desired "off" position, if the yellow goes away then I would test the quad with a battery in it (Props off). If it stays yellow adjust the slider until it is how you want it. There also can be things in the configuration tab, and motors tab, that make the arm switch perform differently than disired. 27-Sep-2023, 02:14 AM (26-Sep-2023, 06:28 PM)Scribble_FPV Wrote: woH woH What is the LED on the receiver doing? If it's doing a triple blink, you need to go into the ELRS lua on your radio and disable model match. If it is already set to Off, turn it on briefly then off again. 27-Sep-2023, 02:51 AM (27-Sep-2023, 02:14 AM)V-22 Wrote: What is the LED on the receiver doing? If it's doing a triple blink, you need to go into the ELRS lua on your radio and disable model match. If it is already set to Off, turn it on briefly then off again.So it was blinking 3 times so I dissabled model match, and it is now solid whenever I "connect" to it. However still no stick inputs, or anything. 27-Sep-2023, 03:42 AM Do you have telemetry disabled on your receiver? Put both TX and RX into WiFi mode and show screenshots of the webui. https://www.expresslrs.org/quick-start/w...the-web-ui |
Motors not responding to transmitter input(no airmode) | corwin | 1 | 47 | 22-Apr-2024, 05:07 PM Last Post: mstc | |
Issues Installing ELRS Reciever | NyxOTNC | 14 | 1,620 | 04-Apr-2024, 08:07 PM Last Post: tr8d3r8 | |
motors do not spin from reciever. PLZ HELP I NEED TO GET THIS TO WORK THIS WEEK | lottacurry | 15 | 266 | 21-Mar-2024, 10:46 PM Last Post: mstc | |
Bidirectional Dshot: errors when transmitter on | romtrack | 15 | 458 | 05-Feb-2024, 07:29 PM Last Post: segler999 | |
Digital Video Transmitter Pin | Eyes.fpv | 2 | 193 | 22-Jan-2024, 05:02 PM Last Post: Eyes.fpv |
