Threads: 3
Likes Received: 0 in 0 posts
Likes Given: 3
0 I am curious if there are any implications doing this. What I plan on doing is running the antenna wires along the edge of a 4mm arm on x frame using an x4rsb so I have 2 antenna to work with. The antenna will be on opposite sides of the quad so they will still be in a perpendicular orientation. I know that it will affect reception, but the question is, how much?
Threads: 83
Likes Received: 533 in 271 posts
Likes Given: 498
30 So long as the exposed silver tip parts of the antenna is not actually touching the frame you should be ok, I have done that with a couple of my quads and yet I have had no problems, sure does save them from being eaten by the props in a crash.
Threads: 3
Likes Given: 3
0 Awesome. Thanks. Was going to put the antenna into a coffee stirrer to protect and act as an insulator.
