02-Sep-2017, 04:32 AM (This post was last modified: 03-Sep-2017, 07:08 PM by Carl.Vegas.)
So as I've been mentioning for a while it's time to turn the pirat into a martian. I am taking my Ghost Pirat build and putting it into a new frame. I just started the work on it tonight and I expect it to be done by tomorrow.
Considerations that I had to determine:
Before Picture of "the Ghost Pirat"
The quad formerly known as the Ghost Pirat, now known as 'Stein's guts (This one makes me think of Scotty):
Finished assembly:
Final view before re-maiden flight:
Flight video either during testing, or just after:
- What frame to go to?=I went with what is working well for me on my other quad: a Martian III
- Can the existing guts be put on the new frame without any rewiring?=It appears so. There is some extra slack on the wires to the ESCs but I don't think they're long enough to cause any problems.
- If it's not a pirat any more what should the new name be?=I decided it's a bit of a Frankenstein now so I decided to go with 'Stein for short. This time there wont be any visual tie in unlike the other version of the build and my first build.
- Do I want to mount the stack differently?=Yes, I decided to use nylon standoffs instead of my long metal screw solution. This should help me get back a few grams and will help reduce noise I suspect. The biggest risk is the little nylon nuts that mount on top of the flight stack seem a little wishy washy to me but I'll probably glue them in somehow
- I've had a couple of screws strip out on me... I just used my dremmel to turn them into flatheads and got them out that way.
- Screws are too long for the middle 4 holes in the legs and slightly too long for mounting the standoffs under the bottom late without the PDB installed. I've corrected this by adding an extra nut (similar to the technique I used to space my VTX in the previous stack). This seems to have fixed the issue.
- Nuts for nylon standoffs don't seem like they'll stay on: as mentioned above I'll probably just glue them on or something later. It's not the most elegant solution but it should get the job done.
- Milestone 1: Purchase new frame and plan rebuild - Complete
- Disassemble Pirat frame - Complete
- Strategically unhook wires to make reconnection easy without needing to document - Complete
- Store old frame parts as just in case / spares - Complete
- Milestone 2: Disassemble Pirat frame - Complete
- Dry fit parts on Martian III frame - Complete
- Assemble base of new frame - Complete
- Assemble, mount, and reconnect wires in flight stack - Complete
- Mount motors making sure to use blue on all screws (and some specific frame screws as well) - Complete
- Zip tie wires to assure slack doesn't cause potential for damage during crashes - Complete
- Mount the rest of the frame back togehter - Complete
- Test board sensor alignment and each motor in BF to assure correct assembly and continued safe operation, adjust where needed. - Complete
- Milestone 3: Complete reassembly - Complete
- Install action cam camera mount - Complete
- Put props on - Complete
- Strap a battery on and power it up in the field - Complete
- Give it a good fly and see how it feels - Complete
- Modify tune and filters - Complete
- Milestone 4: Test flight characteristics - Complete
- Milestone 5: Come back to intoFPV and update photos and tell everyone how things went - Complete
Finished assembly:
carl.vegas
Current Quads: Operational: Diatone GT2 200 In need of repair: Bumble Bee, tehStein, Slightly modified Vortex 250
