04-Nov-2020, 03:58 PM
That looks awesome! Nice work. I haven't flown a 7" yet, this is making me want to though
Rebel Ruxus "free range" - 7inch freestyle build |
04-Nov-2020, 03:58 PM That looks awesome! Nice work. I haven't flown a 7" yet, this is making me want to though 05-Nov-2020, 12:34 PM (This post was last modified: 05-Nov-2020, 12:38 PM by hugnosed_bat.) looks like slow p-term oscilations. as power to weight ratio isnt that good on big quads, it generaly need very high pid values. i dont own a 7inch but i was watching my buddy having troubles and tune it; i would boost all values by 1/3 to start at and turn off d-min feater. like the look of that build, looks simply as 5inch racers, stack around four arms, nothing else - nice! i dont like the look of the practice friendly huge frames that much. Thanks for the information Banelle and Hugnosed! I will use this to help, bigtime. These bigger quads are definitely more of a challenge to tune than I thought, lol.. time to bust out samurai's tuning guide 19-Nov-2020, 07:11 AM That is one oustanding high quality build. As they say in Jurassic Park "spared no expense". Wobbles - Without blackbox, its difficult to say. Frame oscillation is impossible - happens on 5mm or smaller. Mid throttle noise from ESC. I assume you have 1000uF 35V lowESR soldered to ESC? * You only have 2306.5 on 7". Overproped. * Your quad is relatively LOW authority.. takes long for weak 2306.5 to spool up big heavy prop. * Use as light a prop as possible and biblade. * low authority typically high P, high D, low I. Dont copy, but my quad is P60, I60, D50 * High Iterm "windup" oscillations on roll and pitch.. causes P and D to chase each other. More iterm relax. * Your P/D ratio may be close to 1.0... before raising D like crazy, take small steps (+5) and ALWAYS test fly 20sec max. NEVER remove/disable dterm filter. Before I discovered XClass, I thought my **BIG** quads that can easily lift a 2L were "strong". nope. 7incher is Xing2806.5 9incher is BH2812 14incher is Martin4008 The bigger and heavier, the more momentum. And ofcourse more air = more prop wash. Prop balance even more important... beatup bent props on big quad are big no-no. Do try different brand/model props. But ultimately not all flutter can be tuned out. |
Build Rekon5 UL 5" build | ph2t | 52 | 8,402 | 10 hours ago Last Post: Ktart | |
Build Helios - 3.5” Sub-250g (Sub 160g possible) DJI O3 Drone – Frame/Build Thread | Recursion | 13 | 2,244 | 14-May-2024, 09:55 AM Last Post: FloppyFish | |
Build Micro Apex 4" Build | drumgod | 18 | 1,073 | 09-May-2024, 01:33 PM Last Post: drumgod | |
Build 5in lightweight build | hawk01 | 37 | 1,563 | 22-Mar-2024, 10:56 AM Last Post: Jossey | |
4-6" lightweight quads for freestyle and looks | husafreak | 25 | 1,351 | 04-Mar-2024, 05:46 PM Last Post: husafreak |
