14-Nov-2016, 01:52 PM
Available at Hobby King
DTS Q220 is specially prepared for the experience pilot. This Quad is talking about – Durable
Main Board (Power Board) is using modular design which including camera, Video Transmitter, Flight Control, Receiver, ESC. it provide 5V/3A, 12V/3A for External Camera and can use Low voltage alarm and Tracker function when use with transmitter. Pilot can also use the USB plug to upgrade and modify the setting for the Flight Control System (such as F3, Naze32, CC3D) to handle all kinds of FPV competition.
5.8GHz Video Transmitter support upto 40 channels and compatible with all 5.8GHz Video/Audio Receiver. There are 2 set of LED light to distinguish the front and rear.
Pilot can also install the flight camera such as GoPro and Mobius in DTS Q220. DTS Q220 have modular design and scalability. That’s why DTS Q220 is your best choice!
Size - 220mm
Flight Control - F3
Video Tx - 25mW / 200mW / 600mW (Optional)
Camera Format - NTSC / PAL (Optional)
ESC - 20A / 30A blheli (Optional)
Motor - 2350kv
Blade - 5040 x 3
Weight - Approx. 410g (Without Battery)
Needed To Complete
Tx Rx Goggle Cherger Battery
Size - 220mm
Flight Control - F3
Motor - 2350kv
Blade - 5040 x 3
Needed To Complete
