Threads: 1
Likes Received: 0 in 0 posts
0 Anybody knows R9M long range module for taranis X9D ?.
I'd like to know: I'm using a Taranis X9D+ with non EU firmware, Could this module works in in my transmitter if i refresh it with a EU firmware?.
I think not but i'm not sure. I can't use it with non EU FW !.
Many thanks.
Threads: 38
Likes Given: 1,881
72 06-Jan-2018, 02:18 PM (This post was last modified: 06-Jan-2018, 02:18 PM by unseen.) FrSky sell both an EU and a non-EU version of the R9M module.
You should therefore buy the correct one for your region. If you use the non-EU version in Europe, it will use frequencies that are illegal for you to use. The EU version uses 868MHz and the non-EU version uses 900MHz.
Stamping over mobile phone calls and 4G broadband with the non-EU version of the module will cause big problems for the current users of this frequency. It will also make the module's range useless as it will be drowned out by the signals already present on the 900MHz band.
