QX95 Betaflight PID settings dump
Hi guys,
With Cleanflight the stock settings  for F3 EVO brushed FC worked for me well but after flashing Betaflight
I'm strugling with setting up angle mode on Betaflight for QX95 frame.
Can someone share PID setting so I can try out ?
I was trying to play with PID's manually but I was not even close to what I wanted to achieve.
Sticks were overresponsive albeit playing around with RC rate and expo Sad
Cheers!
I've got both a beecore F3 and a Eachine F3.  They are not mounted or tested, but I've attached dump files of the default settings from each.
Maybe that will at least get you back to flyable (just in case you need that). That's all I got.
.txt   eachinef3dump.txt (Size: 7.66 KB / Downloads: 1,377)
.txt   beecoredump.txt (Size: 7.59 KB / Downloads: 569)
Much aporeciated Smile
  Data CLI dump for TMOTOR 13A F411 AIO ph2t 3 858 03-Apr-2024, 06:03 AM
Last Post: ph2t
  Throttle curves on Betaflight? husafreak 7 232 26-Feb-2024, 04:39 PM
Last Post: drumgod
  CLI Dump for Flywoo Flylens75 (original) Oscar 0 376 05-Feb-2024, 02:07 PM
Last Post: Oscar
  Help Cannot change video transmitter settings MerkD 12 314 28-Jan-2024, 09:52 AM
Last Post: MerkD
Question Help Flywoo Firefly No Connect to Betaflight surfwaxamerica 5 305 31-Dec-2023, 07:34 PM
