13-Jan-2018, 06:03 PM (This post was last modified: 13-Jan-2018, 10:16 PM by xcalibur. Edit Reason: Added photos )
Just updated companion to 2.2.1 and did the following:
1. Made sure I have the correct profile selected.
2. Switched my QX7 on in bootloader mode and plugged in USB cable.
3. Checked for OpenTX updates and when prompted downloaded and flashed 2.2.1 to my Taranis.
Unplugged and did a power cycle. On booting it complained about SD card version which I expected. Turned off the TX and tried to load Bootloader so that I can write the new contents to the SD card.
NO BOOTLOADER!! On pressing the trim switches and on button, the screen lights up and when I let go of the buttons everything turns back off.
I then copied 2.2.1 to my SD card firmware folder manually and did a "Flash Bootloader" to see if it will fix the problem.
No such luck.
Any ideas on how to fix this?
No such luck.
If my post helped you...hit the RATE button.
