01-Feb-2017, 03:18 AM
Hey everyone,
I've got a turnigy evolution on its way to me to replace a flysky fs-i6 transmitter. When I was looking through the stats of the evolution it states that it is compatible with the IA6B reciever which is what I already have installed. Does this mean all I need to do is bind the transmitter to the receiver and do the necesarry steps in beta flight? If this is the case is there any reason to install the new receiver that comes with the transmitter? I have copied the features below.
Features:
• AFHDS 2A RF protocol
• Compatible with the iA6, iA6B, iA6C, i10 & i10B range of receivers
• 8 channel 2.4ghz radio with telemetry capability
• i10 style customized Gimbals with dual ball bearing supports
• Illuminated gimbals (adjustable)
• Soft rubber grips
• Easy to use touch screen
• SBUS/IBUS and CPPM/PWM support
• 5 Model Memory
• Backlit LCD Screen
• 4 Stick Mode Selection
• USB port for Flight Simulators
• USB charging
Thanks!
Features:
• Soft rubber grips
• 5 Model Memory
• USB charging
Thanks!
