Threads: 47
Likes Received: 114 in 84 posts
Likes Given: 76
1 15-Dec-2017, 10:10 PM (This post was last modified: 16-Dec-2017, 06:24 PM by s3npai.) I am pretty sure I know the answer, but I want to verify it before I go about thinking wrong and frying a unify.
Going to hook up my Unify Pro 5V to a CL Racing F4 board. The voltage/amperage rating for the VTX/Camera on the board is 7.6V @ 1.2A. The VTX is rated at 4.5-5.5V in @ 600mA. So this tells me the amperage would be too high for the VTX and could potentially fry it. So I would next want to run it from the LED 5V pads on the board. They are rated at 5V, but say do not run more than 500mA. So that would seem futile as well. Has anyone run a Unify Pro 5V off of one of these boards?
Threads: 672
Likes Given: 2,027
139 15-Dec-2017, 10:59 PM (This post was last modified: 15-Dec-2017, 11:00 PM by Oscar.) The output of 7.6V @ 1.2A on your FC means the that pin gives 7.6V and you can draw 1.2A of current from it without burning the voltage regulator on the FC. 1.2A is more like the tolerance, your FC will supply as much current as your VTX needs, it doesn't mean it will pump 1.2A to your VTX constantly.
But 7.6V is too high for the Unify Pro 5V, you can actually fry the VTX because of the excessive voltage.
I believe there is a built-in 5V regulator on the CL Racing F4 with 1.2A rating, so you should be able to power your VTX with 5V.
Not sure where you get the max amp for LED pad from, if there is really a current limit it's probably due to the size of the copper trace...
Threads: 30
Likes Received: 1,199 in 755 posts
Likes Given: 714
45 According to the specs, the board also has a 5V 1.2a BEC. It's just not filtered
Threads: 125
Likes Received: 3,738 in 2,835 posts
Likes Given: 99
388 The amp rating for supply isn't what it pushes to the device. It is the max the device can draw from the supply. So you can't over power a device by hooking it up to a high amp power supply.
The 5V are clearly marked on the FC.
Threads: 47
Likes Given: 76
1 Thanks for all the help everyone! I happened to have a chain going with Mr. Lin from when it was warrantied. I asked him and he said to put it up to the 5V led pad. So on we shall go!!
