20-Sep-2023, 06:06 PM
Hi guys.
I have a couple of questions about the signal strength of my quad. Both video and rc signals.
I have built a volador vd5 dc with o3 air unit, radiomaster elrs rp1 receiver, radiomaster boxer, and goggles v2.
I use 150hz packet rate and dynamic power on the internal elrs module. Also I have installed the fcc hack on goggles v2 sd card.
I have set on my transmitter an rssi dbm alarm at -104dbm since the limit on 150hz is -112dbm.
I have been flying my quad the last few days on top of a hill and when I drop it lower and behind some trees I get rssi alarm and also the image in the goggles get really bad. I think I noticed the bitrate as low as 5Mbps.
I tried to fly the quad high to try how it behaves without obstructions. At around 500m I got rssi warnings again. The LQ dropped at around 80. And the video bit rate dropped at around 30Mbps.
I have to mention that I was inside my car when I was flying the quad. Could this be the reason that I have warnings at such short distance? Should I check something else?
