Threads: 2
Likes Received: 0 in 0 posts
0 What's up guys? I have the Quanum v2's, and they seem to only get a signal whenever they want to. I actually got in an entire battery yesterday, but today they just don't want to link to the vtx. Everything is plugged in and secure. Do you all know what's up? I'd like to get some practice in, but they or the antennas are very temperamental. Sick of LOS. Not really, but omgfpv!!!
Threads: 672
Likes Given: 2,030
139 firstly i would check the cable and connectors, especially solder joints if there is any
do you have a picture of your setup?
Threads: 70
Likes Received: 742 in 378 posts
Likes Given: 577
44 Plug the VRX to the TV set to check if You have image. If it's good, check the monitor - there are very poorly soldered joints on quanums monitor cable (the Y point where two connectors meet). Ground cable of mine snapped mid flight in there. Another possibility is that the connector inside the monitor got loose.
Threads: 2
0 Hey fellas. Thanx a lot for the replies. I really appreciate it. I got it working. The plug wasn't all the way in. It appeared to be just from looking at it, but after pushing it a bit. It worked. I didn't even know someone replied to my thead. I didn't get any alerts.
Thanx again tho.
Threads: 672
Likes Given: 2,030
139 You should get notifications when someone reply to your thread... maybe you have turned it off in your settings?
