Threads: 2
Likes Received: 0 in 0 posts
Likes Given: 0
0 I need some professional advicexperience, I'm using the Nano N32, TTL adapter, Quanum receiver/ Transmitter. I can go to baseflight and toggle controls , buttons etc..with remote and save the changes but when I turn remote on and it lights up, it doesn't work?
Threads: 3
Likes Received: 36 in 20 posts
Likes Given: 6
1 29-Mar-2017, 09:46 PM (This post was last modified: 29-Mar-2017, 09:48 PM by Helibus. Edit Reason: corrections ) When you go back into baseflight, is the expected configuration still there?
This maybe isn't directly applicable, but it sounds similar to a problem I was having with Cleanflight and a Scisky Naze 32 derivative. I'd periodically save changes and after that, the quad would (artificially) bind but nothing would work. Going into Cleanflight, the configuration would be all messed up, including selection of the wrong receiver type. Based on the Scisky seller's suggestion, what I found was that the USB cable was apparently bad or too light of a wire gauge and something would get corrupted in the save process. No more problems after replacing the cable with a newer one meant for high-rate phone charging.
