Quanum Pico (on Whoopee)
Quanum Pico Controller, (Spektrum)
I have this bound to a DX9, red LED on constant.
I have blue LED switching off for Maual Rate, on for Angle and Horizon
I have the green LED Flashing slow on power up, then three fast flashes, then off.
If I tip the board the Green LED flashes as expected.
BUT, I cannot get the green LED on steady which I assume means I cannot arm the board. No motors run.
Can someone with this board take me through the steps to set up arming please?
I have mine (Scisky, but same controller) bound to my DX8.
In cleanflight, minimum throttle is set to 1100, minimum command is set to 1000.
On my DX8 I have throttle travel set to 125% (both directions). These settings allow me to arm via the left (throttle/yaw) stick - I don't use a switch.
  • Bad Raven
Thanks, the cleanflight settings are the default and what I had, but I'd not increased the throttle travel enough. Have just set 140% both ways and it now binds (I have it on a switch)
