02-Jul-2016, 12:59 AM
Just switched out old emax esc's for flycolor raptors. Whenever i give it light punches of throttle, it dips forward and left. Weight and props are balanced...
any suggestions?
any suggestions?
quadcopter dips forward when throttle up |
02-Jul-2016, 12:59 AM Just switched out old emax esc's for flycolor raptors. Whenever i give it light punches of throttle, it dips forward and left. Weight and props are balanced... any suggestions? 02-Jul-2016, 01:03 AM Did you calibrate the new esc's after the change? Verified all esc's have the same settings in blheli? You will also need to retune the quad's PID for the new setup as well, make sure I gain is high enough, it's there to hold the angle well. 02-Jul-2016, 01:03 AM I'll throw more I at it and a new tune at it... thanks a lot for the suggestion |
Quad fall of the sky when doing small throttle move | Snyfir | 11 | 629 | 09-Sep-2023, 10:28 PM Last Post: hugnosed_bat | |
Cineon C30 fall of the sky when doing rapid throttle move | Snyfir | 5 | 434 | 04-Jun-2023, 06:28 PM Last Post: Lemonyleprosy | |
Help Slowly pitching forward at all times | Suros | 10 | 366 | 27-Apr-2023, 08:21 PM Last Post: Suros | |
“Floaty” drop throttle not responding issue | Rob Axel | 0 | 245 | 13-Jan-2023, 03:06 PM Last Post: Rob Axel | |
New Product BetaFPV X-Knight 35 FPV Quadcopter | Bajora | 12 | 1,204 | 02-Jan-2023, 09:32 PM Last Post: iFly4rotors |
