Quadcopter buzzer beeps when not armed throttle zero
When i arm the quad and don't touch the throttle i get a single beep every second from the buzzer. as soon as i put on some throttle, the beeping stops until i put my throttle to zero again.
From what i've read in the documentation, that might be normal behaviour if i were keeping the sticks in disarm position, but i'm not doing anything, i just armed the quad.
I am using SPRacing F3 FC.
yes that's the ARM_beeper, which you can turn off i think: set beeper_off_flags = 32768
(01-Oct-2016, 07:04 PM)SkinnyShark Wrote: yes that's the ARM_beeper, which you can turn off i think: set beeper_off_flags = 32768
And in case it's a newer betaflight, it would probably be "beeper -armed".
Or one of the other armed-states, not sure. Here's the wiki, you have to scroll down a bit: link
  • Oscar
  Quad fall of the sky when doing small throttle move Snyfir 11 628 09-Sep-2023, 10:28 PM
  Cineon C30 fall of the sky when doing rapid throttle move Snyfir 5 434 04-Jun-2023, 06:28 PM
Last Post: Lemonyleprosy
  “Floaty” drop throttle not responding issue Rob Axel 0 245 13-Jan-2023, 03:06 PM
  New Product BetaFPV X-Knight 35 FPV Quadcopter Bajora 12 1,203 02-Jan-2023, 09:32 PM
Last Post: iFly4rotors
  High KV motor with 6s Pack and Throttle Limit thrasher7811 14 9,126 22-Aug-2022, 07:15 AM
Last Post: romangpro
