17-Mar-2016, 04:29 PM
Hey Folks,
I could really use your help. I'm running betaflight on a cc3d board. I was finally able to flash my esc with blheli 14.4
These are the esc's I have:
http://www.banggood.com/ZTW-Spider-Serie...46402.html
I flashed them with blheli 14.4 blue series multi 12a esc. Left all the settings default
This is the result I get...
The motors seems to spin up properly in the motor tab. Even with pid at 0, 0, 0 I get the same result. Does anyone know what might be causing this? I should mention that when it flips out, I'm just using very little throttle. And yes I did calibrate the esc's
