Quad problem (Vortex 285)
Hello,
wanna ask, if someone can know where is problem.
Quad flyes normaly if i dont make any aggresion moves (full throttle) or flips.
When i throttle up, then make flip (or without flip sometimes) when i try to fall for few secs (i mean after full throttle and then minimum throttle), i cant throttle up again.
Looks like when i disbalance quad from his comfort zone, it stops flying... motors stays on minimum rates, dont wanna spin faster again.
After morots stop react on throttle, i can still little bit drive quad with that minimum motor rotation, but i stil falling down.
It happens sometimes, now it happen always when i try flip.
I make some tests on quad at home in cleanflight, but didnt find anything wierd. I bet on problem with flight controller but it look fine
can you do the same test on your bench, remove your props first?
(06-Mar-2016, 08:59 PM)Oscar Wrote: can you do the same test on your bench, remove your props first?
Hi, thank you for reply.
Yeah, i removed props , and try motors, in cleanflight , and with radio. Nothing wierd Undecided
I try to simulate throttle on max, then to minimum and flip then maximum but ... you know quad is on the table...
Wow, maybe found something, i look on motor bars, propellers off, using my radio and it is wierd now, will post more info in few moments
O m g ..
PID tuning ... ?!
I found diference .. i am not sure if this is it.
When is there multiwii rewrite... motors vs throttle (and other sticks) act wierd
After i change to harakiri or multiwii lastest, its loook better ...........
I record video... in few moments ... Seriously it can cause crash ? It can be it ?
After i use protune in osd (i mean make some change and then load new seting), i will find multiwii rewrite in cleanflight.. i dnk if it is good or bad
Ou maaan if that is it....
i fall quad 6 times (one on rock ...... little damage) when i testing where is problem ......
It is strange (thinking why this started), i think i didnt change anything ( i have one crash after long time, on grass and broke propeller hard ), and i also put new reciever orange V2 (V1 before)... it was + - same time when this problem occured.
YOUTUBE LINK (mby few sec/min, but upload was finished)
Strange thing is, when i try usual fly without flips and agresive maneuvers, it was ok .......
I am not sure if this was the problem, will test it tomorow if weather will be ok
Well,
it was PID setting problem ... Whitch i really didnt expect to be.
It is ok .. for now Smile . I can flip and everything without any problems
See ya
I must unfortunately say, problem is back, i bet on ESC. I will order one and see, what happens after change
Hey,
i have the same problem. do u know now whats the problem is?
  Discussion Who's Got the Heaviest 5" Freestyle Quad? SnowLeopardFPV 9 5,350 26-Jan-2024, 12:18 PM
Last Post: hawk01
  Build Rescue Quad iFly4rotors 177 13,488 09-Nov-2023, 09:57 PM
Last Post: iFly4rotors
  I've got a doozy of a problem with my radio mattyfleischfpv 3 314 23-Oct-2023, 07:48 PM
Last Post: mattyfleischfpv
  Build What motors for 4" power quad? romangpro 30 2,310 21-Sep-2023, 02:26 AM
Last Post: romangpro
  Quad fall of the sky when doing small throttle move Snyfir 11 630 09-Sep-2023, 10:28 PM
