Threads: 8
Likes Received: 6 in 6 posts
Likes Given: 45
0 19-Feb-2022, 05:54 AM (This post was last modified: 19-Feb-2022, 06:00 AM by Mr_Stripes.) Exactly what the title says. I actually just saw a post on another forum that I am active on and someone had this problem too. I still have the board (betafpv 12a aio v2.1). I just wanted to know if any of you big brains know what is wrong with it. If you can figure it out I would be stoked.
Thank you for your time.
Threads: 49
Likes Received: 713 in 524 posts
Likes Given: 477
93 Can you describe the problem a little better? Is this happening with props on? Hs it always done this or is it a new issue? DVR or blackbox logs would be a plus if you have them.
Threads: 8
Likes Given: 45
0 Props on and i dont have dvr or blackbox logs the fc doesnt even have black box.
Here is what is going on:
You arm the quad and it acts like normal. Then once you push throttle past 20-25% the quad goes to 100% throttle and no stick inputs do anything. Once you disarm it goes right back to normal until you push past that throttle point. I think the first time I had the issue was after a crash. Maybe the quad got screwed up somehow.
Threads: 14
Likes Received: 47 in 41 posts
Likes Given: 10
2 and when you checked the mechanics and it still does this, apply betaflight defaults for filters and pids. Maybe even go to 0.8 on filters and reduce PIDs by 20% and try again.
If it goes away you got a noisy or faulty build or the board/gyro is crap. I had an iflight FC once that was unflyable that did the same thing
Threads: 8
Likes Given: 45
0 For whatever reason turning off antigravity mode fixed it. Anyone know why? I dont even know what antigravity mode does, thats one of those things I leave alone.
