Quad flips on takeoff.
Hi everyone. I took some advice and recently ditched my broken cc3d flight controller for a spracer f3 board and am now running cleanflight. It looks to be better then ground control station. However I am having problems on takeoff. Motor 4 (front left) won't spin up unless I hit the throttle hard on take off. If I just gradually increase the throttle the other three motors spin up and cause it to flip. If I hit it hard it jumps into the air and everything is good but I have to try and correct for the angle it takes off. All the motors spin up when I calibrate the esc in cleanflight.
All the motors were working fine with the cc3d so I'm somewhat perplexed. I've looked online and can't seem to find the solution I'm looking for. After I get the quad in The air it flys fine. I am really liking the new software I just would really like to know how to fix the motor issue. Anyone have any ideas?
Is there and adjustment I can to to just that motor?
Check min throttle values in blheli. It sometimes happens that they are different and can be too low on that one esc. You can also set min throttle in betaflight a bit higher. If that doesnt help. Try to switch this escandmotor to another arm. Or only the esc in question.
  • NimhBot
(05-Sep-2016, 09:40 AM)Konrad Stepanajtys Wrote: Check min throttle values in blheli. It sometimes happens that they are different and can be too low on that one esc. You can also set min throttle in betaflight a bit higher. If that doesnt help. Try to switch this escandmotor to another arm. Or only the esc in question.
Thanks for the reply Konrad. Now here is a noob question. You say check them in blheli. Is that part of clean flight or a different application I need to find and download. Do I need special hardware to interface with the esc and blheli? Sorry if these are lame questions.
What escs are you using?
(05-Sep-2016, 10:45 AM)oyvinla Wrote: What escs are you using?
12amp esc with blheli firmware.
Not sure the brand. They came in a kit.
(05-Sep-2016, 10:55 AM)NimhBot Wrote: 12amp esc with blheli firmware.
Post a photo of them or link the kit.
BlHeli Suite is a different application, but we need to know what ESC's you are using to tell you more.
Are you using the Emax 12amp ESCs?
I had a similar problem with them.
lol FPV
Ragg-e WBX 5"
BUILD
MY CHANNEL
You do need to download blheli suite and then connect to the escs . Make sure props are off. Make sure props are off . Make sure props are off.
Ok you'll need to have them powered up by your lipo .
Then you need to read setup.
It will tell you if any are out of sync .
Should be master 1
2 slave
3 slave
4 slave
(05-Sep-2016, 01:42 PM)PoorMan FPV Wrote: You do need to download blheli suite and then connect to the escs . Make sure props are off. Make sure props are off . Make sure props are off.
Should be master 1
         2 slave
          3 slave
           4 slave
not to confuse things, but it can say out of sync if you reversed any motors via blheli suite.
Also, check and make sure each esc is of the same firmware version, you may have 3 from one batch and 1 from another with different versions on.  Always a good idea to flash the latest firmware to all your esc's at the same time.
Oh, and make sure props are OFF the quad. Big Grin
My youtube channel
  • NimhBot
Guys wait until NimhBot responds - if those are EMAX 12A we shouldn't even talk about blheli settings as they probably can't be set to connect BlHeli Suite trough servo wire Wink But they may be Kingkongs as they are also being bundled in kits now.
Also if they are EMAX 12A, as lolFPV suggested, they just have trouble with syncing at startup, especially on 3s, setting higher min_throttle may help here.
[-] The following 2 users Like KonradS's post:
  • NimhBot, lolFPV
Thanks for all the tips and help everyone. Sigh... Yes they are emax 12 amp with blheli firmware. Probably not very good esc's.
This is my first "real" quad.
Sounds like I should try and adjust the min throttle in clean flight then. I do recall when I was using the cc3d and I was doing the motor esc calibration that this particular motor had to have a higher min-throttle number then the other three. Is that something that's easy to fix in cleanflight?
I haven't reversed any motors in software. Just two have the wires swapped to spin inverted Smile
Oh. And yes I am using 3s lipo.
Cleanflight misses this simple min throttle configuration for every single motor that Open Pilot has. Try calibrating a few times, if that doesn't change, raise min_throttle setting in small increments until all motors start together.
I remember that what fixed it was.... placing lipo under the quad - what I mean is that after applying only a bit of throttle, my stubborn esc was able to sync with motor as quad had to balance itself on the pack. Of course you can put there whatever you have on hand ie. a piece of foam, that doesn't have to be your lipo.
  • NimhBot
(05-Sep-2016, 06:34 PM)Konrad Stepanajtys Wrote: Cleanflight misses this simple min throttle configuration for every single motor that Open Pilot has. Try calibrating a few times, if that doesn't change, raise min_throttle setting in small increments until all motors start together.
That's an interesting idea. I'll try it later after I make the family breakfast.
Do you mean put the lipo or object under the quad during calibration or permanatly so it has to ballance every time it takes off? Thanks very much for your help.
I think I'll try to adjust the min-throttle in small amounts like you suggested. I'd rather not fly with the lipo on the bottom. I'd assume it would get smashed and bashed up as I usually land kind of hardWink
Although I could just aim to land in the trees and get a tree hugger badge as well. Smile
No, calibrate normally. Just place something under the quad before every start so it doesnt lay flat on the ground. You can try just zipping a bit of foam, it should be easiest Smile
#15
(05-Sep-2016, 07:31 PM)Konrad Stepanajtys Wrote: No, calibrate normally. Just place something under the quad before every start so it doesnt lay flat on the ground. You can try just zipping a bit of foam, it should be easiest Smile
Thanks. That's an excellent idea. Perhaps to lessen the weight of the quad I could make a custom launching platform with a raised area to ballence the quad on for take off.
Or just set it on one of the other lipos that I have.
Smile
I really appreciate the help Konrad.
  Flight controller not communicating with ESC on Quad j2hamster 5 2,302 17-May-2022, 02:57 AM
Last Post: kafie1980
  Quad throttling on arm JinxFPV 2 320 30-Mar-2022, 07:10 PM
Last Post: JinxFPV
  I mapped the quad incorrectly from remapping it Femstar 12 477 03-Nov-2021, 10:33 PM
  Help How to troubleshooting ESC or Motor Problem on Micro Quad? sdamer59 9 1,112 18-Jul-2021, 02:07 AM
  Help Quad shaking during throttle Remi 12 2,548 05-Jul-2021, 10:13 PM
Last Post: Remi
