07-Mar-2016, 07:27 PM
I would like your guys opinion on which one of these would you build or have built? Pros/cons of each would be fantastic.
Qav250 or SparrowR4 |
07-Mar-2016, 07:27 PM I would like your guys opinion on which one of these would you build or have built? Pros/cons of each would be fantastic. 08-Mar-2016, 07:57 AM (This post was last modified: 08-Mar-2016, 07:58 AM by BigglesFPV.) (07-Mar-2016, 07:27 PM)Alex Wrote: I would like your guys opinion on which one of these would you build or have built? Pros/cons of each would be fantastic. I have the QAV250 and Sparrow R3, Both quads are excellent. This is only my view on the 2 quads mentioned. QAV250. Pros Easy to build. Fairly tough (but see cons). Fly's great when tuned right and of course subject to the experience of the pilot. Will fit a GoPro or Runcam, Mobius etc. Cons Limited battery size if you use the battery space between the top and bottom plate, as the battery will butt up against the FC or hang out the back, or both. The PDB in my view limits the size of ESC's you can fit..Forget KISS 24map, Littlebee 30amp and the like, unless you put the esc's on the arms. The frame warps, has a slight twist in it even from new. and a decent hit causes de-lamination of the carbon pretty quickly The VTX antenna may come into contact with the battery. The LEDS are a waste of time and really serve no purpose unless you intend flying LOS all your life, and even then they are limited. Overall on a scale of 1 to 5 with 5 being Awesome, I give it a 3.5 I can only comment on the Sparrow R3 here. Pros Looks awesome, Fly's great Well laid out XT60 adaptor screws to top plate Loads of options available for it from the designer and reseller, can even make the Sparrow quad into a Hex. Cons Can be tricky to build for a newbie into quads. Overall on a scale of 1 to 5 with 5 being Awesome, I give it a 4.0 Both of the quads are good, and both require you to be a contortionist to get everything in the way you want, The QAV pdb setup is a real PIA to be honest. As I have both I can honestly say I do not fly either any more, For the most part I fly my 210 size and 180's. 08-Mar-2016, 11:45 AM Great feed back! Thank you |
1st QAV250 build help | HotaruT | 9 | 711 | 19-Aug-2021, 04:54 PM Last Post: HotaruT | |
Build QAV250 with 16mm standoffs | beatbox | 0 | 463 | 16-Dec-2018, 11:12 AM Last Post: beatbox | |
Build QAV250 Guidance & Autonomy Testbed | Hs293Go | 5 | 2,865 | 20-Jan-2017, 07:30 AM Last Post: Aaron | |
Help HELP Qav250 thrust problems... | Sitebort | 5 | 1,472 | 18-Feb-2016, 09:10 PM Last Post: Jordan Marinov |
