18-Feb-2017, 06:38 AM
The new QAV-XS is Lumenier's new stretched X frame. The frame measures 180mm from the center of the front motors to the center of the back motors, and about 137mm across from the center of the front and rear motors. The frame is 4mm thick with chamfered edges which gives it a very nice super clean look. The top plate is 2mm thick, which also has chamfered edges. It is a mono frame so the arms and main part of the frame is one piece. But the carbon feels really stiff and durable so it's safe to say that if you break an arm on this frame most likely you're going to have to replace more than just the frame.
So for this build, I want something that's going to be aggressive in the turns, with a lot of torque, but with just enough top end speed to really scream in straight aways. But yet still smooth as butter. So my build list is,
KISS FC
KISS 24A-RE ESCs (which came from the factory already flashed with 1.08 which means they should be dshot ready).
Tiger F60 Pro - 2500KV Motors
Matek HUBOSD8-SE
Immersion Tramp VTX
RunCam Swift RR Edition
FrSky XSR Reciever
KISS FC
Matek HUBOSD8-SE
Immersion Tramp VTX
FrSky XSR Reciever
