11-Jul-2022, 12:48 AM (This post was last modified: 11-Jul-2022, 03:14 AM by relentlesstech.)
After having 6 Tattu lipos get damaged in the past month from relatively mild crashes, I started contemplating ways I could protect my lipos, without adding a lot of extra weight - While I was at Walmart looking for double-sided tape, I had a brainstorm as I glanced at the stationary section - In front of me were these interesting items called 'Plastic Insert Dividers', which my mind immediately created a mock-up of how it would look, and work. After testing on the 2 6s Tattus I have left, I decided the idea was definitely solid enough to share, so here you guys go!
Items needed:
This was the lightest option I could think of, and it definitely makes the battery more durable!
Items needed:
- Plastic insert dividers (From Walmart, or any stationary store)
- Scissors
- Thin double-sided tape
- PVC heat shrink tubing (I use 90mm for 6s batteries)
- Heat gun
Please help me build my YouTube FPV channel: RelenTechFPV
