Propeller with motor compatibility
Hi
Can this propeller
https://www.masterairscrew.com/products/...4pEALw_wcB
Fit this motor, maybe with an adaptor?
https://www.kdedirect.com/collections/ua...5215xf-330
It should fit, if you buy the adapter they recommend. The adapter said M8 shaft and the prop can fit over that M8 shaft.
  • DragonTheta
Thank you. Is that the KDE adaptor? It looks like it's designed for something different. Is there another adaptor?
Yes the KDE adapter. They have RH and LH. Not sure what you are using the motor for. If for multi-rotor, then I suggest just getting the LH (CW thread) and buy nylon nuts.
https://www.kdedirect.com/collections/mu...f-pa620-lh
  • DragonTheta
Thank you. I noticed this propeller has a pitch of ten, and the recommended propeller for that motor has a pitch of five point three. Will the propeller with the pitch of ten be compatible with the motor or will I need to run it at a lower speed or something?
I don't know the exact conversion between your biblade vs the maximum limited the manufacturer recommended for your motor. Which is 21.5 x 7.3 triblade.
Your prop you linked has a pitch of 8 not 10.
If you over prop, you can risk burning the motor or esc. Or you can be completely fine. Manufacturer has always recommended parameters and people have always test the limits. The risk you take.
  • DragonTheta
Thank you. And what are the nylon nuts for?
Nylon Loc nut is the best things to prevent the nut from spinning loose.
Question Help Diatone MXC Taycon Cinewhoop's 4th motor isn't working rr240 1 48 23-Apr-2024, 10:09 PM
Last Post: mstc
Question Help Diatone MXC Taycon Cinewhoop's 4th motor isn't working rr240 0 43 23-Apr-2024, 09:36 PM
Last Post: rr240
  Sometimes a motor surprises you - in a good way mstc 20 809 10-Apr-2024, 09:00 PM
Last Post: mstc
  Help Brother Hobby Motor VY1507 hawk01 3 99 05-Apr-2024, 07:58 AM
  Help Mobula 8 after crash motor ramp up to max with minimum throttle johnny1234 7 945 31-Mar-2024, 05:43 AM
Last Post: spiralthomas
