problems binding receiver on mobula 6 2024
Hello everybody, I'm having problems binding my receiver to my drone in  betaflight. its elrs, and I have another drone that I bound to my receiver before so I don't know where I'm going wrong. I also somehow didnt backup my original settings from the factory and ended up like reflashing my firmware and all kinds of stuff to get this to work. I have a backup of someone elses mobula 6 2024 settings but whenever I try to restore it with that, it keeps throwing some errors and wont backup the full settings. so I'm not sure what is going wrong.
Any help would be greatly appreciated. Please let me know what you would need to see to help out. Thank you so much
I read the new 2024 mob6 ELRS has the latest firmware on it..you may have to update your controller / module. I think I read it on the HDzero forum
ok ill give that a try, thank you
edit- put them on the same version and still having the same problem Sad
Do a search, it said there was information somewhere .. I just can’t remember..sorry
OK so i got it to say telemetry recovered telemetry lost but it still isn't actually binding. i feel like im so close, here's the screenshot where my biding phrase uid looks like 0,0,0,0,0 but up top its the correct one? any idea on how to get that bottom one to change to the correct one casus i feel like thats my problem. i already tried to set it through the cli but it still does the same thing
Attached Files Thumbnail(s)
(26-Mar-2024, 06:48 PM)Rob Axel Wrote: Do a search, it said there was information somewhere .. I just can’t remember..sorry
ok yeah ill look at that too, you mean the hdzero forum on here?
If you go into the LUA script on your radio, you can see whether or not your radio is bound. There will be a C in the upper right corner if it is connected to the RX. Or there will be the link RSSI icon on you radio screen but that maybe harder to identify.
If you are not bound, then you can either set the passphrase in the receiver tab, or if you do not have one, use the bind button in the same tab.
https://www.expresslrs.org/quick-start/binding/
If your radio is bound and you are not seeing any inputs in BF, go to Lua script, make sure you set the packet rate to 500hz or lower (150hz is good). If that still doesn't work, then turn ON model match, save it, and turn it off again and resave.
(26-Mar-2024, 07:39 PM)mstc Wrote: If you go into the LUA script on your radio, you can see whether or not your radio is bound. There will be a C in the upper right corner if it is connected to the RX. Or there will be the link RSSI icon on you radio screen but that maybe harder to identify.
ok thank you so much I see the C in the lua script so I am bound and ive tried lower packet rates too to no avail. ill try the model match on thing though. and hopefully get that to work.
Wth.. what version of ELRS is your controller on? Apparently the new mob 6 HDzero is ELRS 3.?..
ok so i tried the model match thing and it still doesn't work. I'm at a total loss here, I have no idea why i would be bound and im seeing my original drone model and also there's an other models tab. but I'm still not getting any stick movement or showing up in betaflight
If you updated or erase your BF firmware, you should restore to factory settings. You can load it from HM website, or at least apply the settings from the manual.
Enable SERIAL_RX on UART1 in the ports tab.
In receiver tab, set to SERIAL (via UART) and CRSF protocol.
https://www.happymodel.cn/wp-content/upl...manual.pdf
In general one thing to remember: all elrs Mobula 6 prior to 2024 had a SPI receiver, in which the elrs code is embedded in BF. You bind in BF.
The elrs Mobula 6 2024 version has a UART receiver. You bind via the 3-plug-in method.
And, of course, the major versions of elrs must match between the receiver and transmitter. I believe the Mobula 6 2024 is running elrs 3.x. You can check the transmitter by running the lua script and seeing the version at the bottom.
[-] The following 2 users Like segler999's post:
  • whattheheck345, Rob Axel
(28-Mar-2024, 02:35 AM)mstc Wrote: If you updated or erase your BF firmware, you should restore to factory settings. You can load it from HM website, or at least apply the settings from the manual.
yeah that's how i have it set. and i still dont get stick movement. but the controller is bound?
(28-Mar-2024, 02:43 PM)segler999 Wrote: In general one thing to remember: all elrs Mobula 6 prior to 2024 had a SPI receiver, in which the elrs code is embedded in BF.  You bind in BF.
thank you so much!!! this was it, the 3 plug method. i tried it at the beginning but it wouldn't go into the binding mode for some reason but i reflashed the firmware and started from scratch and did the 3 plug and that solved it. so weird because i thought i remembered something like if you have a binding phrase on your receiver there's no way a drone will go into binding mode with the manual bind like that. I've been messing with this for like 2 weeks now and can finally fly my new toy Smileour my hero lol
  Betaflight not displaying stick position in receiver menu Monchichack 3 206 11-Jan-2024, 08:25 PM
Last Post: Monchichack
  Receiver to betaflight FLYBT1 4 370 25-Dec-2023, 11:54 AM
Last Post: FLYBT1
  connecting problems Multirotor 0 226 15-Dec-2023, 10:07 PM
Last Post: Multirotor
  Receiver tab and channel values Carlosmoga 0 323 29-Jun-2023, 03:47 PM
Last Post: Carlosmoga
  Bind OK but not input in receiver tab Skylex77 9 420 15-Jan-2022, 02:56 PM
Last Post: Skylex77
