Problem wiring receiver to FC
I'm sorry, but I'm out of ideas. I can't see any reason why it wouldn't work and from what I can see in the code, that release does support PWM for the x-racer.
Hopefully, someone who has the same receiver will see this thread.
how the channels mapped on radio???
Is AETR1234, i played with letters of AETR but nothing changes.
I think i have to do something else in an 8 channel receiver, because this AETR1234 works well for a 4 channel receiver.
#19
My best advice would be to buy a modern FrSky receiver that has s.bus output.
It will be much smaller than the one you have, all the channels are on a single wire and the update speed is much faster than a PWM receiver.
#20
Yes i think is the a good idea.
Something like X4RSB or the new R-XSR Rx with a XJT or R9M module.
[-] The following 1 user Likes alexandros_'s post:
  • unseen
  Problem with opening bootloader Adicjusz 1 128 25-Mar-2024, 08:04 PM
Question What is the best antenna for goggles with ONE receiver (Ls800d)? samysh 16 511 14-Mar-2024, 07:11 PM
Last Post: brettbrandon
  Connecting IA10B receiver to SpeedyBee F4V4 Ladu 2 126 12-Mar-2024, 05:46 PM
Last Post: Ladu
Question Elrs receiver blinks green once? FeuerKai 5 190 09-Mar-2024, 10:05 PM
Last Post: FeuerKai
Exclamation HGLRC M100-5883 Wiring Fault Coleon 6 255 22-Feb-2024, 10:03 PM
