Problem of esc ?
Hello everyone, I've been having this problem for days that makes me think,
I was doing a pid configuration and after several days that I set everything in the various tests in Angle mode at a certain point when you were arming the drone it started in the air very fast and you could not control it, but first it gave me a feeling of unresponsive drone to the commands Replacing the esc with another solves the problem ..
is it possible that was that?
thank you
Quote:Luca_sho_
No.
Its not ESC problem.
Air Mode means when you bump quad it reacts. When you land it bounces. If it gets hit when armed it will jump.
Your real problem is high noise or high D causing "fly away."
  Help TMotor F55 Pro ii ESC won't power FC after crash EyeBotXander 2 278 11-Apr-2024, 09:32 PM
Last Post: EyeBotXander
  Solved ESC and FC rebooting during motortest zsolth 5 130 11-Apr-2024, 01:34 PM
Last Post: zsolth
  Solved Cannot connect ESC derange 2 162 22-Mar-2024, 10:05 PM
Last Post: derange
  Solved Cannot recognise 1 Esc at 4in 1 Esc Mad35 11 231 12-Mar-2024, 01:47 PM
  Help ESC working but motor not spinning Prashant1901 1 149 10-Mar-2024, 02:09 AM
