09-Jul-2022, 04:53 PM
One thing I don’t like about Orqa or anything else that uses micro hdmi cables and HDZero uses mini hdmi.
I have looked and looked for micro to mini hdmi connectors with right angle ends and I haven’t found anything.
I did find a ribbon cable and it works but there’s exposed pads and I don’t want to short them out from touching with fingers or skin.
Unfortunately I don’t think a micro hdmi can be made with a right angle connector or I haven’t seen one.
My plan is to cover the area with 5 minute epoxy but I thought I would ask first if it’s got any conduits in it or if there’s a better insulator.I will also use electric tape to tape ribbon to surface of goggles to prevent ribbon from movements.
Silicone would likely work too and add more flexibility.
Here’s a picture of the exposed pads or solder pins of what I need to insulate and any advice would be appreciated.
Epoxy over time will likely crack over time and might be too brittle so maybe silicone is the way to go.
There’s also shoe goo,E6000 and there’s likely many more that will work.
